What's the best practice for labeling driveway slopes in XS's (see below on right side of road)
I model terrains for each driveway, is there something I can include in the terrain that the annotation group can grab?
I'm new to ORD and may be missing something simple...
Jeff
I have similar task, with no idea ho to fix it for now. In the intersection area, or close to the slip roads nose I am using terrain + surface templates. XS will not recognize these areas as segments - rather two independent points. I tried to configure XS annotation definition to annotate slope between such points but with no success. I gues it is because XS Text Favourite that labels slopes works on segments.
I wonder if we can define segments in other way than by templates, eg point names or feature definitions. Then both cases would be easly solved: my with intersections and yours with driveways.
I hope someone can help with this.
Adam
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
