I am running a system that ties into existing pipes. Got lots of held elevations and Drainage doesn't like it.
Profile Warning for Link 58: ->Invert Below Downstream Pipe ->Check Held Elevations and Slopes Profile Warning for Link 57: ->Invert Below Downstream Pipe ->Check Held Elevations and Slopes Profile Warning for Link 97: ->Minimimum Slope used for Positive Drainage ->Check Held Elevations and Slopes
Anybody else seeing this? System works fine in the ground.
Thanks ,
Bill
These error messages are basically telling you that parts of your drainage netowrk are going up hill. The first two messages are sating that the link in question enters a node at a lower elevation than the outflow pipe of the node. The third message says you have configured a link whos upstream elevation is higher than the downstream. In this situation the link will be automatically reconfigured to use the minimum slope defined in your preferences. Drainage will not allow an up hill pipe.
Note: the differences, especially at nodes can be in 2nd or 3rd decimal place in which case a simple tweak can resolve the errors without affecting the validity of your modeled network. If the exisitng pipes are truly going uphill then it will be a challenge to make the calcs work.
Robert GarrettSenior Product EngineerBentley Systems Inc.
