Show OpenFlows Calculated Slope
From the online help:
Slope - a text manipulator for the slope of the conduit. If Show OpenFlows Calculated Slope", in the Drainage and Utilities category of File > Settings> User > Preferences > View Options - Civil > dialog is set to False, then the slope is calculated using the length of the conduit between the connection regions. If it is set to False, then the slope is calculated using the length of the conduit betwen the centres of the connected nodes. This value will match the Slope (Calculated) value in the Drainage properties. It is read-only.
Both False statements can't be true.  What is the correct way to phrase this paragraph?
  • Hi Josh,
    This is the correct way to phrase this paragraph.
    "Slope - a text manipulator for the slope of the conduit. If Show OpenFlows Calculated Slope", in the Drainage and Utilities category of File > Settings> User > Preferences > View Options - Civil > dialog is set to False, then the slope is calculated using the length of the conduit between the connection regions. If it is set to True, then the slope is calculated using the length of the conduit betwen the centres of the connected nodes. This value will match the Slope (Calculated) value in the Drainage properties. It is read-only."
    A Defect has been filed to have this typo in the documentation fixed.
    Answer Verified By: Ja'Shon Arrington
