My overlay component is not working. It works when tested in the template library but not in the model. It may work 5% of the time. See images below. Any idea as to why it is not working?
Works
Does not work
Seems like its a point constraint problem with one or more of your points. I like to use the "Test Point" in the normal template view to test it both horizontally and vertically to see if issues such as this would exist in my template. More often than not changing your constraints solves this.
apparently this is a bug in 10.08 that is fixed in 10.09
Answer Verified By: Chuck K.
