[Geopak SS10] Unhandled exception in concatenation
Doing nothing but opening a file, I get this error. It may help to know that it is a corridor file, and I feel like I've seen this sort of thing in other corridor-file situations.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
   at System.String.Concat(String str0, String str1, String str2)
   at System.String.Concat(Object arg0, Object arg1, Object arg2)
   at Bentley.Civil.Applications.Survey.Objects.Tools.StringCombineDataImportStructs(List`1 items)
   at Bentley.Civil.Applications.Survey.Objects.SurveySettingsClass..ctor()
   at Bentley.Civil.Applications.Survey.SurveySettings.PersistedSettingsFound()
   at Bentley.Civil.Applications.Survey.SurveySettings.get_Persisted()
   at Bentley.Civil.Applications.Survey.MicrostationSurvey.CleanSurveyData()
   at Bentley.Civil.Applications.Survey.SurveyProject.MicrostationSurveyDeactivate()
   at Bentley.Civil.Applications.Survey.SurveyProject.CloseProject()
   at Bentley.Civil.Applications.Survey.SurveyProject.MyDetach(Boolean projectUnload)
   at Bentley.Civil.Applications.Survey.SurveyProject.CloseForm(Boolean projectUnload, Boolean forceDetach)
   at Bentley.Civil.Applications.Survey.SurveyAddin.CloseSurvey(Boolean projectUnload, Boolean forceDetach)
   at Bentley.Civil.Applications.Survey.SurveyAddin.SurveyAddin_NewDesignFileEvent(AddIn sender, NewDesignFileEventArgs eventArgs)
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at Bentley.Internal.MicroStation.EventHandlerSet.Fire(Object eventKey, Object sender, EventArgs e)
   at Bentley.MicroStation.AddIn.raise_NewDesignFileEvent(AddIn sender, NewDesignFileEventArgs eventArgs)
   at Bentley.MicroStation.AddIn.generateNewDesignFileEvent(SByte* filenameP, Int32 when)
   at Bentley.Internal.MicroStation.CoreHook.DispatchNoHandler(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
   at Bentley.Internal.MicroStation.CoreHook.Dispatch(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
Running Microstation 8.11.09.916 and Geopak 8.11.09.918.
