Hello all,
We have been using this mdl tool,"ctcivil.ma" for the longest time to generate curve data table on construction sheet. It's a great tool nonetheless.
Just checking if you know how to automatically add the feet symbol at the end of radius, T, and L? It's been done manually for the longest time, as a long time cadd user, one less mouse click is a luxury.
I tried modifying "Design File Settings" and Dimension settings, no luck. Please see attached picture for clarification. We are using V8i SS4.
Thanks in advance!
You have to tell us much more.
How is ctcivil.ma related to the Bentley Civil apps (Openroads, Inroads, MX , Geopack)?
Frank
If it is a customised MDL application, it is more than likely that the code that is writing the text would need to be amended. I agree with Frank Klein - more info needed.
Perhaps I should clarify my question. How do you efficiently generate a curve data table on a sheet that has multiple curves like the example I shown? I have been using this ctcivil tool a long time. Can't remember where I got this, I thought it comes with the software, may be I am wrong. Anyway, I simply click on any curve and it will compile all the curve data as shown on the top table. Problem is I like it to add the feet symbol as well. For example, display 300.00' instead of 300.00. That's what I would hope of doing. It's ok to manually add the feet symbol by hand but just wonder the what if....
What software are you running with this extra tool?
v8i (SELECTseries 4), I simply call out this ctcivil.ma from the MDL box.
