My working units are set to “US Survey Feet” and my survey file (.sdr) is in survey feet, but when I reduce the data, Openroads thinks the survey data is in Feet and converts all my survey data from feet to survey feet. Due to this, all my survey points are shifted horizontally, yet my elevations are correct. I’m using Openroads connect v. 10.09
if I change my working units to “Feet” the coordinates match up. Is there anywhere to tell Openroads the incoming data is already in survey feet, and not to convert it?
Would you send me your .sdr file, and I will take a look at it. You can use the link below.https://bentley.sharefile.com/r-r1cdb1954d7e142739558d0e7135f89d6Regards,Jacob
Would you mind posting the solution here and verifying it as an answer. Hopefully it will help someone else in the future!
Regards,Jacob
