I am using ORD 202 release 1 ver. 10.08.00.88
My existing terrain contour labels are coming through in color. Sometimes yellow, sometimes green. I can't find the setting to change the labels, just the contour lines themselves. Has anyone else run into this?
Check the text style associated with the contours. Based on your screen capture it appears to be "CDOT_Standard-Center Center". If you open the text style manager you should be able to change the color here:
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Answer Verified By: Marcus Blake
That did it, thank you!
