Variable "CIVIL_LABEL_HPI = PI" not working
Civil Annotation Computed Prefix Override Names variable "CIVIL_LABEL_HPI" not working.  All the others, at least those I changed seem to work but the HPI override to PI will not work nor does any value added to the variable.  It always show has HPI.  the others are work fine.  The variables below are set.  Using OpenRoads Update 3.
# Civil Annotation Computed Prefix Override Names
CIVIL_USE_CUSTOM_POINT_LABELS  = 1
CIVIL_LABEL_START                              = POB
CIVIL_LABEL_END                                  = POE
