Any tips on what the workflow would be to solve this situation? Roundabout approach civil cells with overlapping templates. Adjust the 2 templates start/ends so that they do not overlap and then model the in-between or is there a cool tool for this kinda dilemma...
What I would do is create a fillet between the 2 control lines, snap each linear template extent to the end of the fillet, and after adding levels to the fillet, apply a linear template to it aswell.
That should result in a pretty clean solution.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
