This post ties in to my earlier post about modifying Profile Named Boundaries.
Sometimes there is a need to modify a Plan Named Boundary. Perhaps you don't need to show part of the last sheet that lies beyond the project limits, or you need to modify a shape's vertices for various reasons. I tried this in the Drawing model, but there is no way to change the reference clipping boundary in the Drawing Model. I then modified the Named Boundary manually in the Design Model. However, the resulting Drawing Model's reference files move and they are no longer at the correct coordinates. Is this how it is supposed to work? I can clip or mask the referenced drawing models in the sheet files, but there is no way to expand the Named Boundary outside of it's original limits. You can only clip it smaller or mask part of it.
I would like the ability to change the shape and/or the extents of the Drawing model that ultimately show up on sheets. Is this possible?
It was much simpler with the Plan and Profile Generator in GEOPAK without the need for intermediate Drawing Models. I'm not seeing the advantage of this new workflow.
The new workflow is advantageous if you get everything right the first time. I have not found a reliable means to edit or modify plan view named boundaries. If there set wrong, its a re-do of placing the named boundaries. Similarly, if the horizontal alignment is changed - the named boundaries do not automatically adjust - resulting in a redo
We are having the same issue. We would like to shift the beginning sheet to capture more plan view at the beginning of the alignment. Is there no good way to do this? Perhaps someone from Bentley could weigh in? I don't find the redo option very acceptable, especially if we have already annotated some of the drawing models associated with this alignment.
Hi Josh,
Have you tried to adjust the named boundaries in plan (in main view) by dragging the handles? You should be also able to move the named boundaries. Then in corresponding drawing model, in attachment dialog select the referenced model and put back x and y offset values to zero - this will ensure that coordinates in drawing model correctly match the design model. The clipping boundary should adjust automatically. If you change size of the named boundaries then you may also need to adjust location of the referenced drawing model in sheet.
Mariusz
OpenRoads Designer 2022 R1
We had the same/similar issue. We wanted to capture more plan before the beginning of the alignment (essentially shift the first sheet to the left and the rest adjust automatically). The only solution we could come up with is extend the alignment and redo the sheets.
Josh M said:However, the resulting Drawing Model's reference files move and they are no longer at the correct coordinates.
I think that both Named Boundaries and Saved Views are both based on using the center of the View. So if the size of the view boundary changes, the view center changes and since the Reference attachment is using the view center as the insertion point, the Ref attachment will appear to move.
This problem was highlighted during the Mstn V8i SS3 beta almost a decade ago. It will probably take some effort to unfreeze the DV biniaries, make the changes, test and debug all those code modules that 'touch' DVs... hopefully someone left a back door open, or sumpthink.
Ideally, the SV and NB process should allow the user to define an anchor point that is independent to the view boundaries. One idea is to include an ACS with the SV. Something similar would be needed for the NB tool / workflow.
