OpenRoads - WorkSet Location
For obvious reasons, projects are stored on a different location for our company's server. Does the WorkSet have to be in the WorkSpace folder?? Can I move this to a different location for existing projects?
Thanks!
  • You can have the WorkSet wherever you want. When you create a WorkSet, by default it is created in <WorkSpace>\WorkSets' folder. The WorkSet '.cfg' and '.dgnws' files are also stored (by default) in the <WorkSpace>\WorkSets folder.
    Does the WorkSet have to be in the WorkSpace folder? No. When you create the WorkSet, you can select the parent folder from anywhere.
    Can I move this to a different location for existing projects? Existing WorkSets will have a line in the '.cfg' file telling where they were stored. For example, '_USTN_WORKSETROOT = C:/Bentley Training/$(_USTN_WORKSETNAME)/'. If you moved the project folder, you would need to amend the '.cfg' file to point to the new folder.
  • It may also be important to include the _USTN_WORKSETDGNS = to your project cfg files (after they're created).  This allows ORD to look for the project dgn files in that projects root directory (can be a separate drive letter/path).  We allow the create workset to place worksets in the default location, then copy that project workset folders to that _USTN_WORKSETDGNS = location.  We leave the cfg and dgnws in the default installed workset path location.  It may take some trial and error to test your particular situation, but that seems to work best and retain our standards and DOT workspace files and VBA.
    ORD 2021 R1 (10.10), 2022 R1 (10.11) | MS 10.16
     Bentley Accredited Road Designer Bentley Accredited Road Modeler
      colliersengineering.com
  • Hi Mark
    Is it possible to be flexible with this when you set the project up without altering the workspacesetup file ?  i currently have specified a folder where my work sets are created , but always the same folder . What i would like to do without changing the workspacesetup file (so everyone in the company can have the same file) is be able to select on project creation where the my workset sits,(in the working project file, not lumped with all my other Bentley jobs)
