Hello All,
I'm trying to trim a gap in a horizontal civil geometry element between two other civil geometries. From everything I've read in the help and in various Communities posts, the "Trim Multiple" should still work with civil geometries. In my workflow, I activate the tool -> select the first vertical line -> select the other vertical line using CTRL -> click the the horizontal line between the two. I would expect this to make the line into two intervals separated by a gap, but I cannot get the tool to trim the gap. I tested the same procedure with microstation linework and the tool works as expected (see comparison between blue civil geometry and gray microstation lines below). Has anyone else ran into this issue? Is there another tool that can accomplish this? I would prefer to keep my civil geometry as a base geometry with intervals (in my case an edge-of-pavement line) rather than separate geometries.
Thanks for confirming this, Mark. I submitted a Service Request to get the Trim Multiple tool upgraded for use with Civil Geometries.
ORD 2021 R2 | MS CONNECT 17| PowerGEOPAK SS10
Baylor Wagehoft, PE | Engineer IV - PMIT | bmwagehoft@mstutz.com
We are hiring!
