I have produced cut/fill tadpoles in open-roads however when I export the model to .dwg the tadpoles export as straight lines. I have tried messing around with the output settings to no avail.
Hi Brian
Try removing the civil schema before exporting to DWG:
communities.bentley.com/.../remove-civil-model
Hi Grezegorz,
I tried this but it did'nt work have you any other ideas.
Stephen
Could it have something to do with Annotation Scale/Global Line Style Scale? In the Model properties. I do not know how DWG handles these, but I had that issue with tadpoles in an ORD model, and changing this solved it? It was a long time ago, so I cannot remember exactly which one I changed.
Hi Mark,
Thanks for the advice. This changes the line type into a tadpole so that it shows correctly in open roads. Unfortunately when it exports to AutoCad it returns to a straight line. This was never an issue when exporting from MX. Is there any output setting I can use so that this does not happen.
It may be easier to see whats happening if you post your DGN?
Mark
