I have produced cut/fill tadpoles in open-roads however when I export the model to .dwg the tadpoles export as straight lines. I have tried messing around with the output settings to no avail.
See attachedLINK C 3D.dgn
ok, so the reason it is exporting as a line is because it is one in ORD as well. Try changing it to a Cell with the bad tadpole you want and it should export out the same way.
Mark
