I have copied an SS4 Topo drawing into an ORD Seed file from the state DOT.
The scale of cells and linestyles is now whacked.
I used replace cells to gradually replace all the cells with the cells from the new ORD cell library.
How do I go about replacing / modifying / scaling all the lines and line strings (linestyles) in the ORD drawing?
Why are all the lines and line strings suddenly acting differently in ORD than SS4?
There can be a number of factors at play.
Does your SS4 drawing and your ORD drawing have the same Working unit definitions? That can cause issues with scaling.Are these regular cells or annotative cells?Is your annotation scale the same in each drawing, and are the annotation scales defined the same way?Is your Model Global Linestyle Scale set to match your annotation scale, or is it set to a separate factor?
You can look at the Help file to find where most of these settings are.If you can find and compare those settings between your SS4 drawing and your ORD drawing, we can probably help you figure out where the scaling factors are playing from.
MaryB
Hi MaryB. Both drawings have the same working units. They are all annotative cells. It appears the state has changed the size of the raw cells in the library which caused the need to replace all the cells manually. I think the cells are repaired. I'm not sure where any global annotation scale is set? My drawing scale I have set to 1"=40'. Each cell is inserted (replaced) at a scale of 1, such that the drawing scale controls the size. The lines and line strings however are a mixed bag of sizes. If I draw a line, it is a much different size than what came from SS4, yet if I examine the properties of each, they are the same (except the coordinates and length). I have searched the help for combinations of Global Linestyle scale and find nothing. I knew how to access a model properties in SS4, but cannot find this in ORD? Is there a global annotation scale somewhere also? Not in the help either.
I'm just clicking File - Help - Help Contents. Not sure where else to search. Bentley Support typically ignores my requests for support or they can't address the question, thus this forum seems to be the last resort.
You should be able to reference your R/W drawing into a "clean" drawing and Merge Into Master.But I cannot say that your ORD geometry will be retained as design information. I just haven't done that often enough to know.
Are your linestyles ByLevel, or are they applied to each element?Can you show a screen shot of the properties (including linestyle scale) from one "bad" line in Drawing A, and the same information from a corresponding line in Drawing B?
I was able repair the R/W drawing by "copying" everything into the Seed File.
Yes, I had to export the Alignment out of the bad file, then import it to the repaired file.
Very strange as I created the R/W drawing from the Seed file. Anyway the scale change to 1"=40' repaired the R/W line style.
Now back to my Fenceline problem. Both files show the linestyle properties to be the same. I have the same problem with Gaurdrail. i guess I'll try to change that style to "0", compress out the linestyle, then purge the workspace, then attach the style again and see if it changes. I think it's somehow still hanging on to the SS4 linestyle from the photogrammetrist. These are their lines.
I know I've already done this, but it's all I can do.
I'm attaching th screen captures of the fence line from the 2 different drawings. Nothing to learn here. They are the same.
Well, it does answer some questions. It may not point to a solution, but it tells me part of what ISN'T the problem.
This confirms that the linestyle is indeed applied ByLevel, and not per element. I've chased all sort of scaling issues before where someone drew an element on the correct level, but set the linestyle when they drew the element. They set it to the same linestyle AS the level, but the level no longer controlled that independent line. Trying to figure out why some lines responded to the ByLevel controls, but not "that one" had me going in circles. I wanted to make sure that we didn't accidentally have that situation.
I'm glad you were able to fix your R/W drawing. No idea what that was...
Strange question...if you try that same reference Merge into good clean file with bad drawing "A", does that solve the scaling problem?
I managed to finally get the Fenceline to convert using the process of compressing, deleting the workspace, etc. The Gaurdrail would not convert, so I tried copying the entire file from the reference into the Seed file and it magically worked.
I think that is the process I should have tried right from the start.
For some reason the drawing was hanging on to these old linestyles.
The 2 Topo drawings look wrong on their own (linestyles are tiny even at the 1"=40' scale, but somehow when referenced into a drawing of the exact same scale they look good.
So for now I think I'm good.
I still have a lot of questions about a lot of things, but I'll try to figure them out on my own unless I get really stuck again.
I now need to figure out how to write my point "Decorations" to graphics through the multitudes of steps and things I have to create.
Thanks for your help and patience.
Andrew
I'm glad you were able to get everything up and going.You're right - maybe next time just start by merging your "bad" drawings into a "good" blank file. There's nothing wrong with fixing things if they can be fixed (and sometimes they can). But sometimes they just can't, and I'm glad you have a workaround now.
I know I have seen posts here before about writing in the survey points, so hopefully a search will find you a good direction.
