Is it possible to change vertical exaggeration in named boundaries for Civil Cross Section? Do anyone have any idea how to do it? I am using ORD R3. Please check screen below. Thanks all for help.
Jacek, I am struggling with the same in general.
Once XS named boundaries are created it seems they can not be edited. That's a pain. I would need to change offset when additional roads are added, or bottom clearance when drainage goes deeper than I assumed in the beginning.
Is there a way to edit/adjust Cross-Sections Named Boundaries? If not, I believe it should be.
Hope someone here can share an idea how to workaround this without rework. Notice - we have a number of non-standard singel station Cross-Sections, not just fixed interval and offsets.
Thanks in advance!
Adam
Best,
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
When creating the cross sections, the default exaggeration is given, but you can overwrite that value. But once they are created, they cannot be edited - as far as I know.
Mark, any changes here expected? we would need to be able to edit Offsets, Top/Bottom clearance. Looks editing shapes in 3D may work.
Adam - I am not aware of any planned changes. If I hear of any, I will post.
thanks!
