Hi there, I'm using OpenRoads Designer. For some reason, when I have the properties menu docked it'll be working just fine. However, if I leave the properties palette docked and open a different .DGN, the properties menu will then display "no content to display" when I select an element to display the properties of. I've tried to close the pallet and re-open the properties menu, as well as docking the menu to all a bunch of locations on the screen, and lastly un-docking the menu altogether. It seems that no matter what, the same message displays no matter what type of element I select (include referenced objects).
Does anyone have a fix for this? I just have to close ORD and re-launch the software, but I'd rather not have to do that every time I want to switch between files.
Thanks in advance!
Kelby
Hi Kelby,
I have had this issue for years and was never able to figure out why it happens. Make sure to put a ticket in for this to get it logged as a defect. Its very frustrating when it happens.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi
I've been trying this for half an hour now and so far i haven't got it to fail.
does it happen every single time you change drawing ?
Any chance you can record a short video clip showing it failing.?
Simon Pegg
Hi Simon, I'll be in ORD doing a bunch of design work this afternoon. I will get a screen capture.
As you mentioned it doesn't happen EVERY time (which almost makes it worse).
Yesterday, the properties worked for a while in the new drawing. Then while in the properties reviewing attributes the window glitched and all attributes disappeared and instead displayed the "no content to display" message.
As Mark says it's been going on for years and I can't figure out what is causing it. Yes very annoying and it is still happening in Update 9. I think it is a combination of mouse clicks I undertake.
Ross
Hi all,
I just did Clear Crash and open the file again, it works!!!
