Hi there, I'm using OpenRoads Designer. For some reason, when I have the properties menu docked it'll be working just fine. However, if I leave the properties palette docked and open a different .DGN, the properties menu will then display "no content to display" when I select an element to display the properties of. I've tried to close the pallet and re-open the properties menu, as well as docking the menu to all a bunch of locations on the screen, and lastly un-docking the menu altogether. It seems that no matter what, the same message displays no matter what type of element I select (include referenced objects).
Does anyone have a fix for this? I just have to close ORD and re-launch the software, but I'd rather not have to do that every time I want to switch between files.
Thanks in advance!
Kelby
The only fix right now is to restart the software. Every time this happens, please send a Service Request via connect.bentley.com.
Consultant, Civil Engineering Success Services
Is there a defect number that we could reference when sending such service requests so that the techs know what issue we are logging?
MaryB
I don't have one in the OpenRoads system. Seems like a MicroStation platform issue and I don't have access to that side of the logging service.
I'm sorry to hear that - it sounds as if they've hamstrung your ability to provide support!
Hi James,
This is definitely an ORD issue and I have never seen it happen in Microstation ever. I would guess it is not in the system because we are finding it impossible to reproduce on demand, definitely something to do with intervals or civil data via a reference file...
Mark
