Hi there, I'm using OpenRoads Designer. For some reason, when I have the properties menu docked it'll be working just fine. However, if I leave the properties palette docked and open a different .DGN, the properties menu will then display "no content to display" when I select an element to display the properties of. I've tried to close the pallet and re-open the properties menu, as well as docking the menu to all a bunch of locations on the screen, and lastly un-docking the menu altogether. It seems that no matter what, the same message displays no matter what type of element I select (include referenced objects).
Does anyone have a fix for this? I just have to close ORD and re-launch the software, but I'd rather not have to do that every time I want to switch between files.
Thanks in advance!
Kelby
Unfortunately still happens in 10.12 as well - might see if i can finally reproduce it and put a ticket in...
Mark
Thanks for the feedback!
colliersengineering.com
no luck getting it to happen on demand...
We started having this issue only recently. I did some testing and found that when we attach an older GEOPAK file (one that has a schema attached) as a reference to either ORD (10.10.21.04) or MicroStation CONNECT (10.17.01.62) the properties window stays empty regardless of any element selection.
This is the schema of the GEOPAK file:
Doing a "Fence to File" or upgrading the GEOPAK file to ORD using the Civil File Manager fixes the problem
Also opening the GEOPAK file using NoWorkSpace / NoWorkSet also works with no issues.
I attached the original GEOPAK file and the ORD upgraded one.
DR-KHM-GM-ORD.zip
Benzi:
As we have never used GEOPAK, I cannot comment directly on your findings; however, I can comment (as I stated I would) on the findings of Mr. Shamoun. Our findings are exactly as he has reported. There was an OpenRoads session this past month on cross sections in ORD where the lady presenting the demonstration was having THE EXACT SAME PROBLEM during the demonstration.
Best Regards,
