Hi there, I'm using OpenRoads Designer. For some reason, when I have the properties menu docked it'll be working just fine. However, if I leave the properties palette docked and open a different .DGN, the properties menu will then display "no content to display" when I select an element to display the properties of. I've tried to close the pallet and re-open the properties menu, as well as docking the menu to all a bunch of locations on the screen, and lastly un-docking the menu altogether. It seems that no matter what, the same message displays no matter what type of element I select (include referenced objects).
Does anyone have a fix for this? I just have to close ORD and re-launch the software, but I'd rather not have to do that every time I want to switch between files.
Thanks in advance!
Kelby
Interesting. I don't see it logged in the OpenRoads ticket system so I assumed it's a platform issue.
Consultant, Civil Engineering Success Services
Still reporting this issue recently in 2021 R1. Has there been a solution or defect posted?
colliersengineering.com
Still having this issue in 10.11.00.115 EVERY time I change files. Its making doing quantities infuriating.
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
Power GEOPAK V8i Select Series 10 Version 08.11.09.918 | FDOT SS10 Version 01.04.01
ORD Version 10.11.00.115 | FDOT Connect Version 10.11.00.02
YouTube Page for ORD: https://www.youtube.com/channel/UC3S-94f7_yUJ-GMhMYPhInA
I have not noticed this happening (yet) in 10.12 (2022 R3)... I will keep y'all posted if it occurs.
Mark
Unfortunately, I am stuck on this version until the FDOT workspace is updated. I have noticed this seems to occur a lot more on older files that have been upgraded through the newer versions. I think some of these files I am working on have been around since 10.07. This project has been around forever...
