Hello!
I have created a new workset for a project. All the project will be designed in the same geographic coordinate system. I will have to create differents dgn models (terrain, corridors, drainange, urban services, etc). Is it possible to configure the workset to determine the same coordinate system for all the dgn files? or have I to configure the coordinate system in every single file I create for the project?
Thank you very much
Create a pair of Seed Files for your project (one in 2D one in 3D) and set your coordinate system there. Save settings, and then use those files as the blank templates to create your other files.
MaryB
