Dear sir,
How can I make Curve table for Curve annotation like this -------------------- Instead of this which general annotations in ORD Files..?
Thanks in advance
Hi Sateesh we will also require something like this. Will like to know if you received any response.
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
Hi Sateesh,
If you are still having issues, I have a suggestion. That curve table cell you are looking for is a delivered cell that can be found in the cell library. Here is a screenshot of where I found it.
Essentially in order to replace the default with this cell, you would have to select the annotation cell, and hover over it to get the path at the bottom.
This is the path you will need to follow in the DGN standards's annotation groups to get to where the cell is being set. Then you just replace the default cell with the curve data table cell.
Managed to replicate what I were looking for. only need some fine tuning in my cel file.
