Single Offset Partial/Entire - Looped Alignment
Hello all,
I'm attempting to create an offset horizontal civil geometry from a looped baseline (exit ramp alignment). However, the tool will not allow me to create the offset at the desired distance. I have a hunch that it has to do with the looping baseline and ORD not knowing which side is left or right. Has anyone else ran into this issue?
/cfs-file/__key/communityserver-discussions-components-files/5922/Single-Offset-Entire_5F00_up.mp4
Parents Reply
  • Hi Shawn, thank you for the reply. I tried your solution but still no luck drawing the feature around the loop. For some reason the smart handles are snapping to the crossing point of the baseline? I can place either the offset on the left side (negative offset) to the crossing point, or the right side (positive offset) from the crossing point up-station around the loop. I still have a feeling that the looped alignment is to blame...
    ORD 2021 R2  | MS CONNECT 17| PowerGEOPAK SS10
    Baylor Wagehoft, PE | Engineer IV - PMIT | bmwagehoft@mstutz.com
    Maurer-Stutz, Inc.
    We are hiring!
