Hi
Couple of months ago I created annotated profiles where existing end proposed elevation had 3 decimal according to my featuring group settings I had then. Now I have change these setting to 2 decimal.
But unfortunately these changes don't come through in my already created profiles, just when I start a new model from scratch.
I have searched inside my modelfil but cant find any dgnlib or text favorite to update
I have latest version of OpenRoads Designer
regards
Sigfús
For your existing files you will need to create a new textfavorite in the same files as your profiles then change it in your profile annotation group. Only way I know that it will works.
You can also try synch librairy, but if it’s still not working you will have to create a text favorite
Have you re-annotated the profiles after you made the changes? Changes are not automatically applied to existing data i.e. your profiles.
Hi Mark ( and JeremieDL)
What I have don to solve this is:
I have created new text favorite with 2 decimal and add it to existing annotation group. ( did not help)
I created a copy of existing annotation group, gave it new name ... ( did not help)
I created text favorite inside my model file... ( did not help)
I noticed that I can update from dgnlib... I tried that and unfortunately it did not hel either :-(.
My file is somehow stuck with 3 decimal elevation
Hi Jeremie
I have not access to annotation group inside my model file :-(
