Utility -> Change shape of conduit
I use OpenRoads CE 2020 R2.
I have a conduit with a circular shape. I can adjust the diameter of this shape without any problem.
If I change the shape to a box and ajust the parameters, the shape is still a circle. How can I get the box instead of a circle?
  • Hello,
    Unfortunately the same behaviour is in version 2020 R3.
    When I change Size in tab Drainage> Physical category by Catalog Class then is changed a Section Type, but in this category only, not in drawing, not in tab Utilities.
    It seems the properties are not synchronized with drawing and between other tables in project.
  • Gunther, I would confirm that the setting in the catalog you choose is set to a box shape (I presume it is given the sizes listed, but can't be certain). If that is set, you may be seeing something similar to an open defect I have encountered in the 3D model not respecting user defined settings.
    Defect 1098019:[Subsurface] Wrong conduit shape is drawn in the 3D model
    Steve
    Steven Litzau, P.E. - Senior Consultant
    www.envisioncad.com
    ORD - 10.10.21.04 / 10.10.01.03 / 10.09.0.91 / 10.08.01.33
    Power GEOPAK / Power InRoads - 08.11.09.918
    Civil 3D - 2021 / 2022
