Hi
I have a small project where I have to deliver a horizontal and vertical geometry from an proposed parking lot and a road with a super elevation. How can I export centerline and EOP from my super elevated corridor as a horizontal and vertical geometry?
My though was creating a terrain from the corridor and use it as a guideline to create vertical geometry from.
If one of you guys have a better idea feel free to share :-)
I am using OpenRods Designer
Hi Sigfus,
You should be able to export the corridor geometry from your 2d model using the Export Geometry command. It wont "see" any clipping, etc but should have what you need.
Mark
Hi Mark
Thanks for your response. Unfortunately it did not work in my case :-(
It seems to export to LandXML fine for my corridors geometry?
Answer Verified By: Sigfus Jonsson
It could be something wrong with my corridor... thanks in advance :-)
... you just pick the corridor when you export... or cl and eop lines?
