ORD/OSD - Benching Templates
Hi Community,
I have created a trench template that is made up of  a trench with benching of 2V 1H. When I run this template - which is set to create plan geometry - I currently only get the lines at the grade in which the bench is. Fine. Is there a way to create a plan line to represent the boundary of the template? I have sketched on the attached photos what that boundary might look like in plan.
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5922/6254.png
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5922/4062.png
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5922/3583.png
Thanks in advance
Oliver
