Within the Utility Properties of my node:
In the Station/Offset Reference, the node says Object reference not set to an instance of object. When I try to click the three dots to select an alignment, the message appears as a window and I cannot change it.
Any Ideas?
I am on Openroads Connect Edition 10.13.2.2
201222_PrDrain_SUDA_006.dgn
Hi Kevin
The "Object reference not set to an instance of object" error sometimes signals system-specific issues (in Windows or your ORD installation) but in this case I can reproduce the error on my machine, which probably means your file got corrupted.
Is this happening only with this file? If yes, you could try recreating the design in a fresh dgn.
Answer Verified By: Kevin Hughes
Yes, just this file. It must have gotten corrupted somehow. Thanks for the reply!
