Profile Annotation - Existing Surface Annotated
I had previously posted about this issue before and I'm trying to figure out a solution with having to temporary delete things. Essentially I have a proposed profile for a trail called "VA-Proposed". The areas at the beginning and end of the alignment that I want to match existing terrain exactly. So to do that, I have created a profile for the existing surface called "VA-Existing." I used the "Add Surface to Profile" function which created an additional profile for the specific horizontal alignment. Then, during my corridor modeling, I used the Point Control to set the center line vertical using the VA-Existing and VA-Proposed alignments (see below).
That worked for the corridor modeling, but the problem occurs when I attempt to create a profile. The output that I get from ORD is shown below.
As you can see, ORD is annotating every single line in the existing terrain. It's obvious that it is treating that VA-Existing as another proposed profile. The bottom axis shows both the VA-Proposed and VA-Existing elevations on top of each other which would confirm that thought.
I guess my question is if there is a way to choose which of the vertical alignments (VA-Existing and VA-Proposed) that get annotated in a profile.
