I have a geotechnical bench underneath a fill slope that I am trying to quantify the excavation for. I need this excavation to be separate from the typical cut volume quantity in the End Area Volumes Report. I assigned a volume option of "substrata" to the feature definition, but that doesn't seem to work. I need 3 separate quantities for the cut, fill, and substrata.
Hi PaulSubstrata is for use with Geotechnical Strata Layers.
I would use Custom
Assume your using 2020 R3?
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Yes, I am using 2020 R3. When I try the Custom option, it lumps the excavation from the bench with the excavation from the roadway template. Do you know how I can customize that volume option to get the quantity that I need?
