I brought in a the road foundation under the asfalt surface, but the asfalt / fondation material and sand is double projected under de surface. does anyone know why, and how can i fix this?
is fixed, I made a copy of a template and used it as a surface to apply the fondation material. Unfortunately if the sutfce template is not horizontal it applies the template twice. Strange, but true. When the template is hrozontal there is no problem.. :-)
I had a similar problem with surface template doubling up.
I had set up my surface template with both top surface point unconstrained. I did it this way to make it easier to add into linear/corridor templates.
I traced my issue down to having 2 unconstrained points in the surface template, once I reduce it to only one unconstrained point, the layers no longer doubled up
Mark
