I'm having an issue distinguishing between the two. I'm trying to generate profiles.
Bryan, which Bentley product are you using and what version?
InRoads Suite V8i (SELECTseries 2)
Thanks for confirming. I have moved your post to the correct forum where someone can help you with this.
I'm unfamiliar with "Host file"? Which tool is this for?
MaryB
Drafting -> Plan & Profile Generator -> Sheet Layout
