When I do a search template in the element template drop down, and then cancel out (select 'x') the search field, the entire element template tree expands. Is there a way to collapse the tree down to the root folders?
Hi dsheely
The element template tree will collapse after a program restart.
When you do a element template search, the tree expansion is probably meant as an assisting measure to give you a better overview of the element template library's content. So I would assume this works as designed.
Sometimes after I do a search for a linear template, I want to navigate using the tree since I know where it is but not necessarily the name. In that case, it would be nice to be able to collapse the tree manually without having to click a bunch of tree arrows.
