Are ORD vertical curve length annotations still incorrect?
The screenshot below shows a vertical curve that was annotated using one of my DOT's default profile annotation settings.
The stationing is correct, but the VC length is wrong. The VC length should be a clean 800.00', but displays as 800.14'.
About a year ago, someone asked a similar question on this board. The reply was that it was a known defect that had been fixed in 10.08.00.88. I am currently using 10.08.01.33.
Here's a shot of the text favorite:
The text favorite is set to US Survey Feet. I confirmed that my design file working units are also set to US Survey Feet.
Is this still a known defect?
Parents Reply Children
