How can one cut cross sections in openroads designer and try to load them back into Geopak SS4 Microstation
I started working on a project in Openroads Designer(OD) to pretty much create a profile and see how it would look with a basic template of my typical with my existing terrain, but now wanting to switch back to Power Geopak SS4 to complete the project because OD does not do that great at the little details.  I wanting to Cut the cross sections(XS) of the corridor and be able to reference them into microstation where I can copy or compare to the microstation XS.  Is there a way to do this.
  • The only way I can think of would be to cut your cross section sheets then, in every cross section drawing model, Merge to Master for every section reference. There may be something better, possibly through the version checker or the ability to downgrade a model...But I know it isn't easy. OpenRoads isn't set up to generate editable graphics for cross sections and profiles, and the ability to create that kind of output hasn't really been addressed.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Since Ss4/10 cuts cross section from the 3D files, you might be able to reference in the models from ORD but I doubt that Ss4/10 would recognize the surfaces for earthwork, nor the features for annotations.
    You might need to use LandXML exports of Geometry and Terrain data to recreate the design data so the cross sections contain sufficient intelligence. Hopefully, you don't have to export all 3D features as alignments, but you might.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
