In other threads it is mentioned that Print Organizer has critical errors running with vertical applications, specifically Geopak. I am having the same issue. I can not load a file into Print Organizer without getting an exception. This happens with Geopak both activated and deactivated. This is the message I recieve:
Exception encountered inside [WorkerMicroStationProxy.LoadDesignFile]
The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it is in the Faulted state.
Is there a patch for this? Any workarounds other than using the old batch plot?
Microstation v8i 8.11.05.17, Geopak 8.11.05.39
This was covered in a thread back in December.
http://communities.bentley.com/products/road___site_design/f/5922/t/12377.aspx
Derricke
