I am working through the Learn Server training lessons for OpenRoads but receive an error when opening the downloadable lesson files from the server. The error only allows me to open the file in "Read-Only" mode which prevents me from being able to work through the lessons alongside the instructor.
Full error message:
I am using OpenRoads Designer CONNECT Edition - 2019 Release 2 Update 7 - Version 10.07.03.18.
I've tried doing a "save as" to a different version of the software or simply just saving the file in another location and attempting to reopen it. I've gotten to where I can open the file in editable mode but it loses a lot of the data that was originally included in the file, including some required data for the lessons.
Any help is appreciated. Thanks
You may want to ask about this over on the Bentley Learn forum: https://communities.bentley.com/communities/other_communities/bentley_institute/f/bentley-institute-forum
There have been design data schema changes every couple of releases, leaving anyone with older versions dead in the water. If you are able to have a newer version of ORD installed, you would be able to use those newer files or downgrade them. Unfortunately, then you wouldn't have the older version installed for any projects you may have been working on (you can only have one ORD installed at a time).
Interoperability has become a nightmare with ORD...as in, it doesn't exist.
MaryB
I'll ask my IT department to update my version if possible and add my question into the Learn forum. Thanks!
