Good Morning,
Is there a way to name specific curves in an alignment in OpenRoads Designer? Previously, using PowerGeopak, we were able to name each specific chain so that when the curve data appears on the plan sheets and geometry report, the curve name was shown. I can't seem to find this similar feature in OpenRoads. Any help would be appreciated.
Thank You!
-BB
Benjamin,
I think this is going to depend on if your element is a civil or a MicroStation element within the complex alignment. I used the Arc Between Elements tool to create a curve between two elements. Then I complexed the three elements together. When I went to the properties of the complex and scrolled down to the curve I could edit the Feature Name box to change the name. Maybe this is what you are looking for?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/39845/video-simple-arc-between-elements-tool-in-openroads-designer
Hi Holly, in your explanation you show the Properties dialog. The Fillet properties show the Feature dropdown. In my situation it is not showing the features dialog. DO you know where I can edit the Point number.
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
