I have tried the following article.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/39296/how-to-add-the-view-control-short-cut-on-long-right-click-to-your-workspace
It did not work.
I also tried the following from the ViewSet Readme.txt
Viewset.mvba is utilized in the delivered example workspaces by using the right mouse clickand selecting View Control.
The file:
...\Configuration\Organization-Civil\_Civil Default Standards - Imperial\Dgnlib\GUI\Custom_Menu.dgnlib
...is what provides access to this menu system.
Additionally, this variable needs set to activate in your workspace...
MS_VBAAUTOLOADPROJECTS > $(CIVIL_ORGANIZATION_STANDARDS)Macros/ViewSet
Notes: The viewset.mvba macro is calling the xml settings file (ViewControlConfigurations.xml) that needs to reside in the same folder as the viewset.mvba file unless you use the config variable shown below. The values in this xml file can be adjusted but all of the names in this XML file are called by the mvba so the names of the settings should not be revised. The distances are in percentages of available screen area. The upper left corner is considered the “0,0” percent location. The bottom right corner is then the “100,100” percent location. If you need to put the settings file in a different location, a variable is supported to locate this file at any desired location. Example: VIEWSET_SETTINGS_FILE = C:/My Settings/ViewControlConfigurations.xml
I do get all of the Macros that I can run but, not in the long right click on the screen.
Any suggestions?
Have you put the GUI DGNLIB into the proper location? I suspect that is where the actual menu comes into play.
MaryB
Is this ok?
Yeah, that should be fine. Hmm...
I hope someone with more experience than I can come along because that looks OK on the surface
I got it. The folders and file did not exist where I was pointing for the custom menu.
thanks for your assistance.
Answer Verified By: Garry Spivey
Does that file show up in the File Menu of the Customize dialog box? And can you find it in the list of Context Menus?
If not, check the spelling of the full path filename. I've seen issues where a typo was preventing things from working.
