Hi all,
I am using MXRenew (redesign and rehabilitation) in V8i
When i try to get a report for bulk earthwork (existing to sub-base) the calculation (see attachment for extract of output file) is done but there is no spreadsheet.
I have tried to get the report with/without stripping.
All the other reports work fine.
Has anyone else come across this problem.
What is the answer to this problem.
Cheers
David
A bug has been identified in the V8i release which causes this problem. If you contact Jason Howarth on Support, he can help you work round it . However a refresh build of the V8i build is imminent that will resolve this and other reported issues and I'll be posting information shortly.
Ian
