I need of some assistance from the Bentley hive.
I have an issue where when my cut slope ends and the fill slope takes effect, a gap is left in my corridor end condition before my fill slope takes over. The inverse (opposite is also happening- transitioning from fill to cut slope).
1) How do I close this gap up to have a seamless corridor?
2) How do I create a seamless Design Top Mesh and bottom mesh with these transitioning cut/fill slope end conditions?
Do you have an Feature Name Override set on the cut and fill features, and the components?
No, not this time, unfortunately. Any other thoughts as to what might be the cause?
upload your itl here. so we can take a look.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
If you have a FNO on the features, they should join up and remove the gaps.
Answer Verified By: Matt Bombace
But that was causing me issues last time because I have a left and a right side. I am targeting a Feature Definition on both End Conditions, (FD is designated by a L and a R) which adds a new set of complexity, I believe?.
