Corridor not processing correctly after alignment change
I am using Openroads Update 9 and have updated an alignment, but the corridor has not processed correctly.
The alignment is in a seperate reference file and was updated using a complex redefine of the plan geometry. The profile was then adjusted to work with the new route. Upon returning to the corridor file, the corridor was processed and resulted in the below:
As you can see, it has registered the new alignment (which is the one with the station tags on the left) and applied the corridor to it. However, it has also left a corridor along the old route. The corridor outline follows the new route but the template drops outlines follow the old one.
I have tried this seperately and just updated the profile (and not the plan geometry) and had the same result (though it was only visible in the 3D and sections views).
Any ideas what could have caused this?
Parents Reply Children
