Dear All,
I'm having an issue in editing horizontal alignment after convert into complex geometry. Please advise.
ALEC_ST-GITT Opt 2.dgn
Please give more detail - what are you trying to edit? Moving a point? Changing a radius? Are you expecting us to try every possibility to find what the issue you are facing is?
Dear Mark,
Thanks for your prompt response. I would like to reroute the alignment. However, I was unable to edit the alignment further. Appreciate it if you could help me out on this issue. I'm using the latest ORD edition 2020 release 3 (10.09.00.91)
In what way are you unable to edit it further? Are you seeing any manipulators? If not, have you disabled the element handles in the 'Element Selector' dialog?
I have enclosed the alternative path to append with the previous alignment. I would appreciate if you could show me on how to edit the alignment to connect to the alternative route.ALEC_ST-GITT - Copy.dgn
Top image show the original highlighted, the middle shows the alternative highlighted. Note the red arrows - I have added an arc with transitions at the left, and done a reverse curve to tie in on the right (red arrows) so that the second actually ties in. The bottom image is the result of using 'Complex Redefine' - I selected the first alignment, and swapped in the second one.
Answer Verified By: chandru
Got it thanks.
Excellent - if you could close the thread by selecting 'More > Verify Answer' that would be helpful.
