Hi all, I have all these points in Autocad 2D DWG format with XYZ coordinates. Is it possible for me to create terrain using these point in ORD ?
I think there are 2 or more ways
1) you can plot just the elevations from a csv into ORD then use (create by text interpolation) under the terrain tab and additional methods)
2) Create a txt with XYZ and under same Terrain tab then additional methods use the (create terrain model from Ascci file)
hope this helps i think its what Mark was saying also
Josh
Answer Verified By: Vivian LIM
Hi Joshua, thanks for your reply. I managed to extract the XYZ from autocad and create a text file for that. Then create terrain model from Ascci file. =)
Excellent news - can you use 'More > Verify Answer' to show that the thread is closed pleease? THanks.
