I recently upgraded to MicroStation Select Series 10 from Select Series 4. What do I need to do to have GEOPAK work with Select Series 10? This is what I had previously to open MicroStation with GEOPAK:
"C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.exe" -wrP:\Standards\CAD\V8i\Workspace -wsLoad_GEOPAK_SS3=1
I changed SS3 to SS10 but I don't get the "Applications" menu.
I appreciate any help. Thank you.
Ray
Try changing it back to SS3. I think that's an actual variable in your workspace, and not related to the actual program. If that doesn't work, we may dig deeper.
MaryB
Set the SS3 to SS4. You can go to the GEOPAK startup icon that is created when you install the product. Go to the properties and you can see what is default in the command line.
I upgraded to MicroStation Select Series 10. I did not upgrade to GEOPAK SS10. I was wondering if there was a GEOPAK SS10. I have not found it.
You can only open GEOPAK SS10 in MicroStation SS10. No other GEOPAK can be opened on top of MicroStation SS10 besides GEOPAK SS10. Here's a download link: https://softwaredownloads.bentley.com/en/ProductDetails/1151.
Answer Verified By: Ray Santillan
Thank you very much, Holly! That worked. I appreciate it very much!!
A few of my team members are having issues with GeoPak software where they aren't seeing the "Applications" dropdown menu. After reading through this forum (and doing a bit of exploring on their machines) it seems like the issue is that our MicroStations were updated to SS10 but they're still trying to communicate with our GEOPAK SS3 software. I tried to follow the link to download the new GEOPAK SS10 software but it doesn't seem like it's supported anymore. Is this correct? If so, how do you suggest fixing this issue? Thanks!
I believe you need to submit a service ticket to get Ss10 software at this point.
Okay. I'll submit a ticket with Bentley. Thank you!
