Civil Plan By Element Sheet Seed rotated
Hi
I'm trying to create sheet seed file for plan creation in which the user picks predefined sheet layout shapes  to create drawing and sheet models based on those Named Boundaries.
For that I am using Create Named Boundary tool with By Element option. In result I am getting is rotated by -90 degrees the "drawing detail" thingy  object in relation to the sheet layout.
I am not even sure if this is the correct workflow and toolset for the task.
Here is the result. Of course when I try to cut sheets from that sheet seed the drawing is also rotated in the sheet model. The drawing model view is rotated by -90 deg.
