I'm designing a drainage network in OpenRoads Designer. I added catchments to all my inlets and now when I go to run the design scenario, I get this error:
Before I added the catchments, I was able to run the scenario and get the normal report / error log. Now it won't even begin to compute - Not sure what's going on. I tried un-referencing the active surface and using user-defined areas for my catchments and still no luck. I've seen other drainage layout posts with the same error but not for the analysis (mostly conduit placements).
Here's the full error code:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.NullReferenceException: Object reference not set to an instance of an object. at Haestad.TerrainExtractorNET45.Data.Store.DemDTM.GetDrapeDistanceFromStartAndSurfaceElevationPointList(GeometryPoint3D[] points, Unit sourceUnit, Int32 conduitId, IDomainDataSet dataSet, IField baseNodeGroundElevField, IField baseDirectedNodeGroundElevField, IField startNodeIdField, IField stopNodeIdField) at Haestad.StormSewerProduct.Support.EditorModel.Components.DTM.DTMLinkGroundElevationReader.CreateLinkIdGroundElevationPointHashtable() at Haestad.StormSewerProduct.Support.Actions.Analysis.Calculations.ValidateAction.ExecuteImpl(IQueryApplicationState queryApplicationState) at Haestad.Framework.Support.Actions.ActionBase`2.Execute() at System.Windows.Forms.MenuItem.OnClick(EventArgs e) at System.Windows.Forms.MenuItem.MenuItemData.Execute() at System.Windows.Forms.Command.Invoke() at System.Windows.Forms.Control.WmCommand(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.TreeView.WndProc(Message& m) at Haestad.Framework.Windows.Forms.Components.TreeViewEx.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll----------------------------------------OpenRoadsDesigner Assembly Version: 0.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoadsDesigner.exe----------------------------------------Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.PowerPlatform.FeatureAspects.DLL----------------------------------------System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System Assembly Version: 4.0.0.0 Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------ustation Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/ustation.DLL----------------------------------------Bentley.General.1.0 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.General.1.0.DLL----------------------------------------System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Bentley.DgnPlatformNET Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.DgnPlatformNET.DLL----------------------------------------Bentley.MicroStation.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL----------------------------------------Microsoft.ApplicationBlocks.ExceptionManagement.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.01 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL----------------------------------------Bentley.ECObjects3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.ECObjects3.DLL----------------------------------------Bentley.Platform Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.Platform.DLL----------------------------------------Bentley.GeometryNET.Common Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.GeometryNET.Common.DLL----------------------------------------Bentley.GeometryNET.Structs Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.GeometryNET.Structs.DLL----------------------------------------System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll----------------------------------------Bentley.Exceptions Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.Exceptions.DLL----------------------------------------Bentley.logging-2.0 Assembly Version: 2.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.logging-2.0.DLL----------------------------------------Bentley.Licensing.Client.API Assembly Version: 1.0.0.0 Win32 Version: 11.00.06.13 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.Client.API.dll----------------------------------------Bentley.Licensing.ServiceInterface Assembly Version: 1.0.0.0 Win32 Version: 11.00.06.13 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.ServiceInterface.DLL----------------------------------------System.ServiceModel Assembly Version: 4.0.0.0 Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------System.Runtime.Serialization Assembly Version: 4.0.0.0 Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------SMDiagnostics Assembly Version: 4.0.0.0 Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll----------------------------------------System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------System.ServiceModel.Internals Assembly Version: 4.0.0.0 Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll----------------------------------------Bentley.UI.Vendor.Wpf Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.UI.Vendor.Wpf.DLL----------------------------------------PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll----------------------------------------WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll----------------------------------------PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll----------------------------------------System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll----------------------------------------Bentley.UI Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.UI.DLL----------------------------------------Telerik.Windows.Controls Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.DLL----------------------------------------Telerik.Windows.Themes.VisualStudio2013 Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Themes.VisualStudio2013.DLL----------------------------------------Telerik.Windows.Controls.Input Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Input.DLL----------------------------------------Telerik.Windows.Controls.Navigation Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Navigation.DLL----------------------------------------Telerik.Windows.Data Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Data.DLL----------------------------------------Telerik.Windows.Controls.Chart Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Chart.DLL----------------------------------------Telerik.Windows.Controls.Data Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Data.DLL----------------------------------------Telerik.Windows.Controls.Docking Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Docking.DLL----------------------------------------Telerik.Windows.Controls.Expressions Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Expressions.DLL----------------------------------------Telerik.Windows.Controls.FixedDocumentViewers Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.FixedDocumentViewers.DLL----------------------------------------Telerik.Windows.Controls.GridView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.GridView.DLL----------------------------------------Telerik.Windows.Controls.ImageEditor Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.ImageEditor.DLL----------------------------------------Telerik.Windows.Themes.Office2013 Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Themes.Office2013.DLL----------------------------------------Telerik.Windows.Controls.RibbonView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.RibbonView.DLL----------------------------------------Telerik.Windows.Controls.RichTextBoxUI Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.RichTextBoxUI.DLL----------------------------------------Telerik.Windows.Documents Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Documents.DLL----------------------------------------Telerik.Windows.Controls.ScheduleView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.ScheduleView.DLL----------------------------------------Telerik.Windows.Controls.Diagrams Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.DLL----------------------------------------Telerik.Windows.Diagrams.Core Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Diagrams.Core.DLL----------------------------------------Telerik.Windows.Controls.Diagrams.Extensions Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.Extensions.DLL----------------------------------------Telerik.Windows.Documents.Core Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/Telerik.Windows.Documents.Core.DLL----------------------------------------System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------Bentley.RibbonView Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.RibbonView.DLL----------------------------------------Bentley.MicroStation.Ribbon Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.Ribbon.DLL----------------------------------------Bentley.MicroStation Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.DLL----------------------------------------Bentley.MicroStation.WPF Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.WPF.DLL----------------------------------------MdlSeed Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/MdlSeed.DLL----------------------------------------Bentley.TableUI Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.TableUI.DLL----------------------------------------Bentley.Visualization.RenderRibbonToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Visualization.RenderRibbonToolbar.DLL----------------------------------------Bentley.Visualization.LightsRibbonToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Visualization.LightsRibbonToolbar.DLL----------------------------------------Bentley.Visualization.MaterialsRibbonToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Visualization.MaterialsRibbonToolbar.DLL----------------------------------------Bentley.DrawingScale Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.DrawingScale.DLL----------------------------------------Bentley.ViewGroupList Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.ViewGroupList.DLL----------------------------------------Bentley.ViewGroupHistory Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.ViewGroupHistory.DLL----------------------------------------Bentley.Macros.UI Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.Macros.UI.DLL----------------------------------------Bentley.Macros Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.Macros.DLL----------------------------------------System.Windows.Interactivity Assembly Version: 4.0.0.0 Win32 Version: 2.0.20520.0 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Telerik/System.Windows.Interactivity.DLL----------------------------------------PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll----------------------------------------Bentley.DialogManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.DialogManager.DLL----------------------------------------Bentley.MicroStation.MiniToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.MiniToolbar.DLL----------------------------------------PresentationFramework.Aero2 Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll----------------------------------------Bentley.Connect.Client.API Assembly Version: 1.0.0.0 Win32 Version: 10.00.15.12 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.Connect.Client.API.DLL----------------------------------------Bentley.Connect.Client.Service.Interface Assembly Version: 1.0.0.0 Win32 Version: 10.00.15.12 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.Connect.Client.Service.Interface.DLL----------------------------------------Bentley.StartScreen Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.StartScreen.DLL----------------------------------------Bentley.Recommendation.API1 Assembly Version: 1.0.0.0 Win32 Version: 10.00.15.12 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Recommendation.API1.DLL----------------------------------------WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll----------------------------------------UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll----------------------------------------UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll----------------------------------------Bentley.Geotechnical.Borehole Assembly Version: 1.0.0.0 Win32 Version: 10.05.01.08 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Geotechnical.Borehole.DLL----------------------------------------Bentley.Geotechnical.Commands Assembly Version: 0.0.0.0 Win32 Version: 10.05.01.08 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Geotechnical.Commands.DLL----------------------------------------Bentley.DgnDisplayNET Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.DgnDisplayNET.DLL----------------------------------------Bentley.Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Interop.MicroStationDGN.DLL----------------------------------------Bentley.Geotechnical.TerrainModel Assembly Version: 1.0.0.0 Win32 Version: 10.05.01.08 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Geotechnical.TerrainModel.DLL----------------------------------------Bentley.Geotechnical.Connectivity Assembly Version: 0.0.0.0 Win32 Version: 10.05.01.08 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Geotechnical.Connectivity.DLL----------------------------------------Bentley.EC.AbstractUI3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.EC.AbstractUI3.DLL----------------------------------------Bentley.EC.Persistence3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.EC.Persistence3.DLL----------------------------------------Bentley.BaseSQLPlugin Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL----------------------------------------Bentley.ECSystem3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.ECSystem3.DLL----------------------------------------Bentley.EC.PluginBuilder3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.EC.PluginBuilder3.DLL----------------------------------------Bentley.EC.Controls3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.EC.Controls3.DLL----------------------------------------MarkupAddIn Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/required/MarkupAddIn.DLL----------------------------------------Bentley.CifNET.Loader.Mstn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Loader.Mstn.4.0.DLL----------------------------------------Bentley.CifNET.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.4.0.DLL----------------------------------------Bentley.CifNET.CadSystem.Interfaces.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.CadSystem.Interfaces.4.0.DLL----------------------------------------Bentley.CifNET.Objects.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Objects.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.Interfaces.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Interfaces.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.4.0.DLL----------------------------------------Bentley.CifNET.Geometry.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Geometry.4.0.DLL----------------------------------------Bentley.CifNET.Objects.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Objects.4.0.DLL----------------------------------------Bentley.CifNET.MessageCenter.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.MessageCenter.4.0.DLL----------------------------------------Bentley.CifNET.Formatting.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Formatting.4.0.DLL----------------------------------------Bentley.CifNET.Graphics.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Graphics.4.0.DLL----------------------------------------Bentley.CifNET.CadSystem.Mstn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.CadSystem.Mstn.4.0.DLL----------------------------------------Bentley.CifNET.Dgn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Dgn.4.0.DLL----------------------------------------Bentley.CifNET.CadSystem.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.CadSystem.4.0.DLL----------------------------------------Bentley.CifNET.Model.DataAccess.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Model.DataAccess.4.0.DLL----------------------------------------Bentley.GeoCoord2 Assembly Version: 1.0.0.0 Win32 Version: 03.18.02.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.GeoCoord2.DLL----------------------------------------Bentley.Windowing Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.Windowing.DLL----------------------------------------publishdgn Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/publishdgn.DLL----------------------------------------Bentley.PropertyManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.PropertyManager.DLL----------------------------------------Bentley.ExpressionEvaluator Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/bentley.expressionevaluator.DLL----------------------------------------Bentley.DesignlinksApp Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.DesignlinksApp.DLL----------------------------------------Bentley.CifNET.Objects.Data.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Objects.Data.4.0.DLL----------------------------------------System.Drawing.Design Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll----------------------------------------Bentley.CifNET.DomainModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DomainModel.4.0.DLL----------------------------------------Bentley.CifNET.Model.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Model.4.0.DLL----------------------------------------Bentley.CifNET.Objects.RuleManagement.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Objects.RuleManagement.4.0.DLL----------------------------------------Bentley.CifNET.Annotation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Annotation.4.0.DLL----------------------------------------Bentley.CifNET.ContentManagement.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ContentManagement.4.0.DLL----------------------------------------Bentley.CifNET.ProjectSettingsModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ProjectSettingsModel.4.0.DLL----------------------------------------Bentley.CifNET.GraphicalFiltersModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GraphicalFiltersModel.4.0.DLL----------------------------------------Bentley.CifNET.TMGraphicalFiltersModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.TMGraphicalFiltersModel.4.0.DLL----------------------------------------Bentley.RuleDrivenPresentationECPlugin Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.DLL----------------------------------------Bentley.CifNET.LinearGeometry.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.LinearGeometry.4.0.DLL----------------------------------------Bentley.GeometryNET Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.GeometryNET.DLL----------------------------------------Bentley.CifNET.Geometry.ParametricCell.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Geometry.ParametricCell.4.0.DLL----------------------------------------Bentley.CifNET.Geometry.ScalableMesh.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Geometry.ScalableMesh.4.0.DLL----------------------------------------Bentley.TerrainModelNET Assembly Version: 1.0.0.0 Win32 Version: 08.21.18.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.TerrainModelNET.DLL----------------------------------------Bentley.TerrainModelNET.Formats Assembly Version: 1.0.0.0 Win32 Version: 08.21.18.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.TerrainModelNET.Formats.DLL----------------------------------------Bentley.CifNET.DesignStandardsModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DesignStandardsModel.4.0.DLL----------------------------------------Bentley.CifNET.Model.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Model.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.ContentManagementModel.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ContentManagementModel.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.DesignStandardsModel.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DesignStandardsModel.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.DgnAccess.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.DgnAccess.4.0.DLL----------------------------------------Bentley.CifNET.GraphicalFiltersModel.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GraphicalFiltersModel.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.UI.Controls.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.UI.Controls.4.0.DLL----------------------------------------Bentley.CifNET.ContentManagementModel.UI.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ContentManagementModel.UI.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.Annotation.UI.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.Annotation.UI.4.0.DLL----------------------------------------Bentley.MicroStation.Templates.Support Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.Templates.Support.DLL----------------------------------------Bentley.MicroStation.WinForms.Controls Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL----------------------------------------Bentley.CifNET.TMGraphicalFiltersModel.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.TMGraphicalFiltersModel.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.Presentation.Mstn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.Presentation.Mstn.4.0.DLL----------------------------------------Bentley.CifNET.Objects.Presentation.Controls.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Objects.Presentation.Controls.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.Tool.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.Tool.4.0.DLL----------------------------------------Bentley.CifNET.LinearGeometry.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.LinearGeometry.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.Presentation.4.0.DLL----------------------------------------Bentley.CifNET.Formatting.Mstn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Formatting.Mstn.4.0.DLL----------------------------------------Bentley.CifNET.ContentManagement.Mstn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ContentManagement.Mstn.4.0.DLL----------------------------------------Bentley.CifNET.ProjectSettingsModel.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ProjectSettingsModel.Presentation.4.0.DLL----------------------------------------Bentley.OpenSite.Model.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Site/Bentley.OpenSite.Model.4.0.dll----------------------------------------Bentley.SITEOPS.API.NET Assembly Version: 1.2.0.1 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.SITEOPS.API.NET.DLL----------------------------------------Bentley.OpenSite.Model.DataAccess.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Site/Bentley.OpenSite.Model.DataAccess.4.0.dll----------------------------------------Bentley.OpenSite.SettingsModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Site/Bentley.OpenSite.SettingsModel.4.0.dll----------------------------------------Bentley.OpenSite.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Site/Bentley.OpenSite.Presentation.4.0.dll----------------------------------------Bentley.Civil.RoadwayDesigner.Presentation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.RoadwayDesigner.Presentation.4.0.dll----------------------------------------Bentley.Civil.RoadwayDesigner.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.RoadwayDesigner.4.0.dll----------------------------------------Bentley.Civil.RoadwayDesigner.Interface.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.Civil.RoadwayDesigner.Interface.4.0.DLL----------------------------------------Bentley.Civil.Geometry.Utilities.Drawing Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.dll----------------------------------------Bentley.SurveyToolsNET.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyToolsNET.4.0.dll----------------------------------------Bentley.SurveyToolsNET.Base.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyToolsNET.Base.4.0.DLL----------------------------------------Bentley.CifNET.UI.Tools.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.UI.Tools.4.0.DLL----------------------------------------Bentley.SurveyToolsNET.Objects.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyToolsNET.Objects.4.0.DLL----------------------------------------Bentley.SurveyToolsNET.COM.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyToolsNET.COM.4.0.DLL----------------------------------------Bentley.CifNET.DgnTools.Transformer.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DgnTools.Transformer.4.0.DLL----------------------------------------Bentley.SurveyToolsNET.Microstation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyToolsNET.Microstation.4.0.DLL----------------------------------------Bentley.CifNET.Mstn.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Mstn.4.0.DLL----------------------------------------Bentley.CifNET.UI.Templates.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.UI.Templates.4.0.DLL----------------------------------------Bentley.EC.Presentation3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.EC.Presentation3.DLL----------------------------------------Bentley.Hyd.Haestad.Model Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.Model.dll----------------------------------------Haestad.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.DLL----------------------------------------Bentley.Hyd.CP Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.CP.DLL----------------------------------------Bentley.Hyd.CP.Core Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.CP.Core.DLL----------------------------------------Haestad.Support Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Support.DLL----------------------------------------Haestad.Domain.StormSewer Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.StormSewer.DLL----------------------------------------Haestad.Support.NumericalMethods Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Support.NumericalMethods.DLL----------------------------------------Haestad.Drawing.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Drawing.Domain.DLL----------------------------------------Haestad.Framework Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.DLL----------------------------------------Bentley.Hyd.Haestad.Model.DataAccess Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.Model.DataAccess.dll----------------------------------------Bentley.Hyd.Haestad.GraphicalFiltersModel Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.GraphicalFiltersModel.dll----------------------------------------Bentley.Hyd.Haestad.ContentManagement Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.ContentManagement.dll----------------------------------------Bentley.Hyd.Haestad.GraphicalFiltersModel.Presentation Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.GraphicalFiltersModel.Presentation.dll----------------------------------------Bentley.Hyd.Haestad.Presentation Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.Presentation.dll----------------------------------------Haestad.Framework.Windows.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.Windows.Forms.DLL----------------------------------------Haestad.MicroStation.Support.ViewAttributesDialogAddon Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL----------------------------------------Haestad.StormSewer Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.7 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.StormSewer.DLL----------------------------------------Bentley.CifNET.SDK.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.SDK.4.0.DLL----------------------------------------Bentley.MessageCenter Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/required/Bentley.MessageCenter.DLL----------------------------------------Bentley.MicroStation.Templates Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.Templates.DLL----------------------------------------Bentley.MicroStation.WinForms.ECPropertyPane Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL----------------------------------------Bentley.MicroStation.MaterialControl Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.MaterialControl.DLL----------------------------------------Bentley.TerrainModel.ElementTemplate Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.TerrainModel.ElementTemplate.DLL----------------------------------------TerrainModelHandlerApp Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/TerrainModelHandlerApp.DLL----------------------------------------Bentley.MicroStation.PWCatalog Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.PWCatalog.DLL----------------------------------------Bentley.CatalogService.PublishingDialog Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.01 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.CatalogService.PublishingDialog.DLL----------------------------------------Bentley.ComponentsCenter.ClientApi Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.01 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.ComponentsCenter.ClientApi.DLL----------------------------------------Bentley.CatalogService.CatalogExplorer Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.01 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.CatalogService.CatalogExplorer.DLL----------------------------------------Bentley.Visualization.TypeEditors Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.Visualization.TypeEditors.DLL----------------------------------------ConnectAdvisor Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/required/ConnectAdvisor.DLL----------------------------------------Bentley.RSS.Interop Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.RSS.Interop.DLL----------------------------------------Bentley.Connect.Advisor.Api Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/ConnectAdvisor/Bentley.Connect.Advisor.Api.DLL----------------------------------------Bentley.Connect.Advisor.ApiFactory Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ApiFactory.dll----------------------------------------Bentley.Connect.Advisor.Logging Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Logging.DLL----------------------------------------log4net Assembly Version: 1.2.15.0 Win32 Version: 1.2.15.0 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/log4net.DLL----------------------------------------Bentley.ExtensionDiscovery Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL----------------------------------------System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------Bentley.MicroStation.ECIntegration Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL----------------------------------------ORDLocalization Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/ORDLOCALIZATION.DLL----------------------------------------DcRasterNet Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/PROGRAM%20FILES/BENTLEY/OPENROADS%20DESIGNER%20CONNECT%20EDITION/OPENROADSDESIGNER/DESCARTES/ASSEMBLIES/DCRASTERNET.DLL----------------------------------------Bentley.Connect.Advisor.OopWrapper Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.OopWrapper.dll----------------------------------------Bentley.RasterManager Assembly Version: 1.0.0.1 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.RasterManager.DLL----------------------------------------Bentley.Connect.Advisor.Api2 Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Api2.DLL----------------------------------------Bentley.Connect.Advisor.ServiceContract Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ServiceContract.DLL----------------------------------------Bentley.RuleDrivenPresentationECPlugin.PresentationRules Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.PresentationRules.DLL----------------------------------------Bentley.ExcelECPlugin Assembly Version: 1.0.0.0 Win32 Version: 10.05.01.08 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.ExcelECPlugin.DLL----------------------------------------Bentley.DgnECPlugin3 Assembly Version: 1.0.0.0 Win32 Version: 04.18.02.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.DgnECPlugin3.DLL----------------------------------------Bentley.Civil.Geometry.Services.MX.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.Geometry.Services.MX.4.0.dll----------------------------------------Bentley.Civil.MX.ModelFile.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.MX.ModelFile.4.0.DLL----------------------------------------Bentley.CifNET.Geometry.Services.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Geometry.Services.4.0.DLL----------------------------------------Bentley.Civil.Geometry.Services.InRoads.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.Geometry.Services.InRoads.4.0.dll----------------------------------------Bentley.Civil.Geometry.Services.Geopak.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.Geometry.Services.GEOPAK.4.0.dll----------------------------------------Bentley.TerrainModelNET.Element Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.TerrainModelNET.Element.DLL----------------------------------------Bentley.RSS Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.RSS.DLL----------------------------------------CivilEH Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/CivilEH.DLL----------------------------------------Bentley.CifNET.DocCenter.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DocCenter.4.0.DLL----------------------------------------Haestad.Subsurface Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Subsurface.dll----------------------------------------Haestad.MicroStation.Support Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.MicroStation.Support.DLL----------------------------------------Bentley.Hyd.Haestad.Application Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.Application.DLL----------------------------------------Haestad.LicensingFacade Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Haestad.LicensingFacade.DLL----------------------------------------SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/SandDock.DLL----------------------------------------Bentley.Subsurface.Annotation Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Subsurface.Annotation.DLL----------------------------------------Bentley.Hyd.Haestad.Commands Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.Commands.DLL----------------------------------------Haestad.StormSewerProduct Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.StormSewerProduct.DLL----------------------------------------Bentley.Hyd.Haestad.iModel Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.iModel.DLL----------------------------------------Bentley.Hyd.Haestad.ProductUpdate Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.DLL----------------------------------------Haestad.SUE.CP Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.SUE.CP.dll----------------------------------------Haestad.Drawing.Control Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Drawing.Control.DLL----------------------------------------Haestad.SUE Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.SUE.DLL----------------------------------------Haestad.Mapping Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Mapping.DLL----------------------------------------Haestad.Framework.Windows.Forms.XtraReports Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL----------------------------------------Haestad.ProjectWiseFacade Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.ProjectWiseFacade.DLL----------------------------------------Haestad.Domain.SUE Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.SUE.DLL----------------------------------------Haestad.Domain.ModelingObjects Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.ModelingObjects.DLL----------------------------------------Haestad.Domain.DataObjects Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.DataObjects.DLL----------------------------------------Haestad.Drawing Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Drawing.DLL----------------------------------------Haestad.GraphicsLibrary.Support Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.GraphicsLibrary.Support.DLL----------------------------------------Haestad.ConnectClientIntegration Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.ConnectClientIntegration.DLL----------------------------------------msvcm90 Assembly Version: 9.0.30729.9518 Win32 Version: 9.00.30729.9518 CodeBase: file:///C:/WINDOWS/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9518_none_08e07c8fa840efbe/msvcm90.dll----------------------------------------Haestad.Domain.LibraryObjects Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.LibraryObjects.DLL----------------------------------------Haestad.SQLite Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.SQLite.DLL----------------------------------------Haestad.UserDataExtensions Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.UserDataExtensions.DLL----------------------------------------Haestad.ModelBuilder Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.ModelBuilder.DLL----------------------------------------Haestad.Framework.Windows.Forms.Grid Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.Windows.Forms.Grid.DLL----------------------------------------Washington.MicroStation.CP Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Washington.MicroStation.CP.dll----------------------------------------Washington Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Washington.DLL----------------------------------------Haestad.Water.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Water.Forms.DLL----------------------------------------Haestad.Framework.Windows.Forms.Steema Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.Windows.Forms.Steema.DLL----------------------------------------Haestad.CanvasLibrary.Framework Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.CanvasLibrary.Framework.DLL----------------------------------------Haestad.CanvasLibrary.Framework.Windows.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.DLL----------------------------------------Haestad.Domain.ModelingObjects.Dynamic Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL----------------------------------------Haestad.Domain.ModelingObjects.Water Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL----------------------------------------Haestad.Domain.DataExchange Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.DataExchange.DLL----------------------------------------Haestad.ScenarioComparison Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.ScenarioComparison.DLL----------------------------------------Haestad.Network Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Network.DLL----------------------------------------Haestad.SCADA.Domain.Application Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.SCADA.Domain.Application.DLL----------------------------------------Haestad.SCADA.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.SCADA.Domain.DLL----------------------------------------Haestad.Support.OOP Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Support.OOP.DLL----------------------------------------TeeChart Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/TeeChart.DLL----------------------------------------System.Data.DataSetExtensions Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll----------------------------------------System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll----------------------------------------Haestad.Domain.LibraryObjects.Install Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.LibraryObjects.Install.DLL----------------------------------------System.Configuration.Install Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll----------------------------------------Haestad.Domain.DaoInterop Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.DaoInterop.DLL----------------------------------------Haestad.Calculations.StormSewer.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL----------------------------------------Haestad.DesignStandards.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.DesignStandards.Forms.DLL----------------------------------------Haestad.DesignStandards.Calculations Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.DesignStandards.Calculations.DLL----------------------------------------Bentley.CifNET.GeometryModel.SDK.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.SDK.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.SDK.Edit.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.SDK.Edit.4.0.DLL----------------------------------------Bentley.CifNET.ContentManagementModel.Management.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ContentManagementModel.Management.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.Annotation.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.Annotation.4.0.DLL----------------------------------------Bentley.OpenSiteNET.SDK.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Site/Bentley.OpenSiteNET.SDK.4.0.DLL----------------------------------------Bentley.CifNET.Model.DataAccess.DgnEC.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Model.DataAccess.DgnEC.4.0.DLL----------------------------------------Bentley.Hyd.Haestad.Helpers Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Bentley.Hyd.Haestad.Helpers.DLL----------------------------------------ScaleModels Assembly Version: 1.0.10.0 Win32 Version: 01.00.10 CodeBase: file:///c:/pwworking/central01/d1860776/ScaleModels.dll----------------------------------------Bentley.StatusCursorPrompt Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.StatusCursorPrompt.DLL----------------------------------------Bentley.MicroStation.CursorPrompt Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.CursorPrompt.DLL----------------------------------------CifDWGExportManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/CifDWGExportManager.DLL----------------------------------------Bentley.CifNET.ExampleAnnotations.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.ExampleAnnotations.4.0.DLL----------------------------------------Bentley.CifNET.AssetManager.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.AssetManager.4.0.DLL----------------------------------------Bentley.CifNET.AccuDraw.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.AccuDraw.4.0.DLL----------------------------------------Bentley.CifNet.LinearGeometry.Coordinates.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNet.LinearGeometry.Coordinates.4.0.DLL----------------------------------------Bentley.CifNET.GeometryModel.Tools.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.Tools.4.0.DLL----------------------------------------Bentley.CifNET.LinearGeometry.ComplexConstructions.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.LinearGeometry.ComplexConstructions.4.0.DLL----------------------------------------Bentley.CifNET.TerrainModel.ImportExport.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.TerrainModel.ImportExport.4.0.DLL----------------------------------------Bentley.CifNET.UI.CursorPrompt.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.UI.CursorPrompt.4.0.DLL----------------------------------------Bentley.CifNET.Tools.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Tools.4.0.DLL----------------------------------------Bentley.CifNET.CoreTools.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.CoreTools.4.0.DLL----------------------------------------Bentley.MicroStation.WinForms.Docking Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL----------------------------------------Bentley.CifNET.DgnTools.GeometryBuilder.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DgnTools.GeometryBuilder.4.0.DLL----------------------------------------Bentley.CifNET.DgnTools.Connector.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DgnTools.Connector.4.0.DLL----------------------------------------Bentley.Civil.RoadwayDesigner.Commands.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.Civil.RoadwayDesigner.Commands.4.0.dll----------------------------------------Bentley.SurveyToolsNET.Preferences.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyToolsNET.Preferences.4.0.DLL----------------------------------------Bentley.OpenSite.Commands.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Site/Bentley.OpenSite.Commands.4.0.dll----------------------------------------Bentley.PointCloud Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.PointCloud.DLL----------------------------------------Bentley.RasterProperties Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.RasterProperties.DLL----------------------------------------DcPointCloudNet Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Descartes/assemblies/DcPointCloudNet.dll----------------------------------------DcStmNet Assembly Version: 10.13.2.2 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Descartes/assemblies/DcStmNet.dll----------------------------------------DcSMNet Assembly Version: 10.13.2.2 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Descartes/assemblies/DcSMNet.dll----------------------------------------DgnDisplayUI2 Assembly Version: 1.0.0.0 Win32 Version: 03.18.02.64 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/DgnDisplayUI2.DLL----------------------------------------Bentley.ECObjects.MixedMode3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.ECObjects.MixedMode3.DLL----------------------------------------DgnDisplayCSUI2 Assembly Version: 1.0.0.0 Win32 Version: 03.18.02.64 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/DgnDisplayCSUI2.DLL----------------------------------------PresentationFramework-SystemData Assembly Version: 4.0.0.0 Win32 Version: 4.8.4320.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll----------------------------------------Bentley.CifNET.GeometryModel.UI.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.UI.4.0.DLL----------------------------------------Bentley.ECObjects.Interop3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.ECObjects.Interop3.DLL----------------------------------------Haestad.Support.OOP.Data Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Support.OOP.Data.DLL----------------------------------------Haestad.Framework.ChangeLog.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.ChangeLog.Forms.DLL----------------------------------------Haestad.Reporting.Presentation.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Reporting.Presentation.Forms.DLL----------------------------------------Haestad.Reporting Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Reporting.DLL----------------------------------------Haestad.Domain.DataObjects.Water Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.DataObjects.Water.DLL----------------------------------------Haestad.Calculations.Dynamic.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Dynamic.Domain.DLL----------------------------------------Haestad.Calculations.StormSewer Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.StormSewer.DLL----------------------------------------Haestad.Calculations.HHSolver.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.HHSolver.Domain.DLL----------------------------------------Haestad.Calculations.Scada.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Scada.Domain.DLL----------------------------------------Haestad.Calculations.Scada.ScadaReader Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL----------------------------------------Haestad.Calculations.StormSewer.OutputReader Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL----------------------------------------Haestad.Calculations.Dynamic Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Dynamic.DLL----------------------------------------Haestad.Calculations.HydrologyHydraulics Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.HydrologyHydraulics.DLL----------------------------------------Haestad.Calculations.SWMM5.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL----------------------------------------Haestad.Calculations.HydrologyAndHydraulics.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.HydrologyAndHydraulics.Domain.DLL----------------------------------------Haestad.Calculations.Support Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Support.DLL----------------------------------------Haestad.Calculations.HydrologyAndHydraulics Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.HydrologyAndHydraulics.DLL----------------------------------------Haestad.Calculations.StormDerivedEngine Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.StormDerivedEngine.DLL----------------------------------------Haestad.Calculations.SewerCAD.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.SewerCAD.Domain.DLL----------------------------------------Haestad.Calculations.Pressure.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Pressure.Domain.DLL----------------------------------------Haestad.Calculations.Pressure Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Pressure.DLL----------------------------------------Haestad.Calculations.Pressure.ResultsReader Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.Pressure.ResultsReader.DLL----------------------------------------Haestad.Calculations.SWMM5 Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.SWMM5.DLL----------------------------------------Haestad.Calculations.GravityDerived Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.GravityDerived.DLL----------------------------------------Haestad.Calculations.StormCAD.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.StormCAD.Domain.DLL----------------------------------------Haestad.Calculations.StormCAD Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.StormCAD.DLL----------------------------------------Haestad.Calculations.SWMM5.OutputReader Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.SWMM5.OutputReader.DLL----------------------------------------Haestad.Calculations.EnergyCost.StormSewer Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.EnergyCost.StormSewer.DLL----------------------------------------Haestad.Calculations.EnergyCost.Domain Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.EnergyCost.Domain.DLL----------------------------------------Haestad.Calculations.EnergyCost Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.EnergyCost.DLL----------------------------------------Haestad.Calculations.EnergyCost.ResultsReader Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.EnergyCost.ResultsReader.DLL----------------------------------------Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.Design Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------TeeChart.Languages Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/TeeChart.Languages.DLL----------------------------------------Haestad.NetworkBuilder Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.NetworkBuilder.DLL----------------------------------------Bentley.ECUISupport Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/bentley.ecuisupport.DLL----------------------------------------Bentley.ECBrowserDgnIntegration Assembly Version: 1.0.0.0 Win32 Version: 04.18.02.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.ECBrowserDgnIntegration.DLL----------------------------------------Bentley.MstnPlatformNET.DeletePerforator Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.MstnPlatformNET.DeletePerforator.DLL----------------------------------------Bentley.MultiPointPlacementManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.MultiPointPlacementManager.DLL----------------------------------------Bentley.Printing3D.ProfileSettings Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.Printing3D.ProfileSettings.DLL----------------------------------------Bentley.MstnPlatformNET.DefinePerforator Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.MstnPlatformNET.DefinePerforator.DLL----------------------------------------Bentley.NamedPresentation Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.NamedPresentation.DLL----------------------------------------Bentley.CustomProperties Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.CustomProperties.DLL----------------------------------------Bentley.MicroStation.WPF.Controls Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.WPF.Controls.DLL----------------------------------------Bentley.ECReporting Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.ECReporting.DLL----------------------------------------Bentley.ParametricCells Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/Bentley.ParametricCells.DLL----------------------------------------GoogleEarth Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/GoogleEarth.DLL----------------------------------------Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll----------------------------------------Bentley.CifNET.DgnTools.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.DgnTools.4.0.DLL----------------------------------------Bentley.SurveyNET.SDK.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/OpenRoads/Bentley.SurveyNET.SDK.4.0.DLL----------------------------------------Bentley.DgnGeoCoord2 Assembly Version: 1.0.0.0 Win32 Version: 03.18.02.63 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Bentley.DgnGeoCoord2.DLL----------------------------------------Haestad.Domain.DataExchange.IModel.Forms Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.DLL----------------------------------------System.IdentityModel Assembly Version: 4.0.0.0 Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll----------------------------------------System.Security Assembly Version: 4.0.0.0 Win32 Version: 4.8.4261.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll----------------------------------------Bentley.Geotechnical.Utility Assembly Version: 1.0.0.0 Win32 Version: 10.05.01.08 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.Geotechnical.Utility.DLL----------------------------------------Bentley.EC.DBStructure Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.EC.DBStructure.DLL----------------------------------------Bentley.EC.SchemaMappingAPI Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingAPI.DLL----------------------------------------Bentley.MicroStation.General Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.MicroStation.General.DLL----------------------------------------Bentley.CifNET.Annotation.UI.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.Annotation.UI.4.0.DLL----------------------------------------TextTools Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/mdlsys/asneeded/TextTools.DLL----------------------------------------Bentley.RSS.Common Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/Bentley.RSS.Common.DLL----------------------------------------Bentley.Windowing.Win32 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL----------------------------------------Haestad.TerrainExtractor Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.TerrainExtractor.DLL----------------------------------------Haestad.TerrainExtractorNET45 Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.TerrainExtractorNET45.DLL----------------------------------------Haestad.Shapefile Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Shapefile.DLL----------------------------------------Haestad.LoadBuilder.Calculations Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.LoadBuilder.Calculations.DLL----------------------------------------System.Web Assembly Version: 4.0.0.0 Win32 Version: 4.8.4330.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------Haestad.Framework.Windows.Forms.Reporting Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL----------------------------------------Bentley.EC.SQLAdapter Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL----------------------------------------Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Bentley.General.MixedMode1 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.51 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/Bentley.General.MixedMode1.DLL----------------------------------------ConstraintCommonNet Assembly Version: 1.0.0.0 Win32 Version: 10.13.02.02 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ConstraintCommonNet.DLL----------------------------------------Bentley.CifNET.GeometryModel.SnapRules.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.GeometryModel.SnapRules.4.0.DLL----------------------------------------Haestad.LoadBuilder.StormSewer Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.LoadBuilder.StormSewer.DLL----------------------------------------Haestad.LoadBuilder Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.LoadBuilder.DLL----------------------------------------Bentley.EC.SchemaMappingSQLBuilder Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.53 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL----------------------------------------Haestad.Hydraulics Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Hydraulics.DLL----------------------------------------Bentley.CifNET.TerrainModel.4.0 Assembly Version: 1.0.0.0 Win32 Version: 10.08.01.33 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Cif/Bentley.CifNET.TerrainModel.4.0.DLL----------------------------------------Haestad.Calculations.GVFOutputReader Assembly Version: 10.2.2.5 Win32 Version: 10.2.2.5 CodeBase: file:///C:/Program%20Files/Bentley/OpenRoads%20Designer%20CONNECT%20Edition/OpenRoadsDesigner/Subsurface/Haestad.Calculations.GVFOutputReader.DLL----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Any help / troubleshooting ideas would be greatly appreciated! Thanks!
try detaching unnecessary reference files. Then detach less critical reference files.
New time user to Bentley Community -- first post. If using Drainage and Utilities in ORD -- sometimes the drainage and utilities model gets "corrupted" when graphics are deleted and not their corresponding data in the database. I was able to resolve this error by running a model integrity check then deleting out un-mapped database elements for nodes or conduits which were deleted graphically from ORD. Go to ORD-->Drainage and Utilities-->Tools-->Project-->Model Integrity Check then follow the prompts and/or dialogs to delete un-mapped database items or to synchronize data with graphics (or vise versa). There may not be the need to detach references or run an error check.
