Hi, How is the option to add expresisons to item types made available? When I create a new Property Definition from the Item Types Panel, I dont get the option to add an expresison as shown in link below, I just get Type, Is Array, and Default Value.
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v14/en/BetaExpressions.html
I am using: OpenRoads Designer CONNECT Edition - 2019 Release 1 Update 7 - Version 10.07.00.56
Chris
Hi Chris
That version of ORD is based on Microstation CE update 12 I believe and didn't include Item Type Expressions yet.
You'll have to update to a newer release to get that functionality (eg. 2020 Release 1 for PowerPlatform Update 13 or 2020 Release 3 that uses the Update 14 one with the additional Expression Validation tool).
Mark
Answer Verified By: Chris Hunt
