I have searched and searched the net looking for a solution and have found none. Is this not possible? I have even tried exporting the 2D linework to a V8i version drawing and export the shp file, but no luck.
The only solution at present is to use OpenCities Map.
If you go back to InRoads/GEOPAK V8i, Bentley Map is included with those products that allows for exporting to a shapefile.
Rod WingSenior Systems Analyst
This is the only solution I have found. I had to import the linework from ORD into V8i drawing in-order to get things to work.
If you want to explore another alternative you can contact Krister Surellhttps://communities.bentley.com/members/6e33b71c_2d00_9642_2d00_497b_2d00_b025_2d00_d333d4e59997
His company has a product called MicroStation FDO. It imports shapefiles (among other GIS data types) into MicroStationhttps://consulting.surell.se/fdo-for-microstation/
It doesn't say anything about export, but it might be worth an email to find out.
We export to Google Earth and then use that to convert to a shapefile.
Hi Aaron,
Have you tried using Asset Manager in ORD to do it?
Asset Manager (Technology Preview) (bentley.com)
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
